VapeDroid-X1C2-(S,ST,B) Replay enabled theme 1.0.2
   (0 reviews)
I have modified the original theme to include "Replay" features, this theme allows you to enable the "Use Replay on this profile" in the "Coil" screen, after enabled, it enters into "Replay" mode, and allows you / shows options "Recording" (when firing), "Save" (to save the puff", "Playing" (Replaying), and "Cancel" (stop Playing).
Additionally, it allows to change the wattage and temperature (temp mode with Replay enabled), wattage (no temp mode), Resample Coil (Measure atomizer Ohms again).
What's New in Version 1.0.2   See changelog
Shows the configured power while is "Playing" with regular profile or "Watts" profile with Replay enabled.
Does not allow to "Resample" the resistance  (Coil cold Ohms) while "Playing".
  • Thanks 2
 Share
Recommended Comments
There are no comments to display.
