Black & White - White & Black
Simple. Elegant. Easy on your eyes.
I decided to re-design the iOS Theme for my new mod design. All the multi-colored heavy themes were just too much all the time, so I knew that I had to make something simple this time. I settled on doing a theme that Ι wouldn't get tired of looking at, using the controls of the iOS theme that I really love. After a couple of months of beta testing, I can now officially release the B&W theme.
Are you enjoying this theme? I am currently focused on small unprofitable projects like this and could use the support. You can personally help me out with a small donation by clicking the PayPal button below
Secure link
Main Screens
Ok, lets say your mod is now unlocked. These are the main vaping screens you're going to spend the most amount of time on.
   Wattage:                                        Temp Control:                                Replay Mode:
Menus
The familiar menus from the iOS Theme. They are all white in the White & Black version.
    Coil:                   Preheat/Boost:                Puff info:                      Settings:
Smart Watt Adjust
Haven't seen anyone do this so far, so this is the innovation I'm most proud of. I am both an MTL and a DTL vaper so i understand the frustration of both worlds. We had to choose a theme that allowed us to adjust the watts for our style or settle for with sub-par option. With the new Smart Watt Adjust feature, your wattage will change by 0.5 when you are below 20 watts and by 5 when you are above 100 watts. Everything in between is adjusted by 1. The Gordian Knot is solved, what's next?
(Need to register a wattage number before the change applies)
Are you under the impression that your theme displays the battery level incorrectly? You're not crazy, 99% of the themes are... Using a small "hack" in theme designer, I can safely say that this theme will give you the most accurate representation of your battery level. Added to that, the battery gauges will turn red when you are at 20% or below. Need to charge 'em once in a while!
Swap battery % for time
 I felt like the "time or battery %" option shouldn't be missing from this theme. Some people may be used to it from the iOS theme. The option to choose which one you prefer is once again here.
Color Mapping chart
What's New in Version 1.0.1   See changelog
Hotfix to remove "Replay Capable Coil Indicator" because it is not reliable.
