- SCARLET PASSION:
Thanks to Tortuga for the fantastic background graphics!
PLEASE NOTE:
- all protections against erroneous settings (eg Temp-Protect in power mode), as usual from my enhanced themes
-the functions for REPLAY are only enabled in power mode (material => Watt / as provided by Evolv) and only after activation if the coil is REPLAY-capable.
TO THE EXPERIENCED USERS:
Disclaimer:
Haftungsausschluss:
What's New in Version 4.3.2   See changelog
- hidden, invisible shortcut from the basic mainscreen for configuration of home and lockscreen ("2nd Main" => "(+) Logo")
- Where? Is hidden .... I wrote it anyway 😉
- added missing status field when firing on homescreen
- versteckter, unsichtbarer Shortcut vom basic-mainscreen zur Konfiguration von Home- und Lockscreen ("2nd Main" => "(+) Logo")
- Wo? Ist versteckt.... Habe ich doch geschrieben 😉
emir71
Report ·
Hallo erste mal,
Probier bitte nie neue Version aus - lohnt sich und scheint stabil
Share this review
