3_P_EVOLV_V7-Descrition.png+
See also my other Themes:
What's New in Version 14   See changelog
- bugfix in der Konfiguration von Akkuanzeige und Datum aif dem Lockscreen vom StattQualm-Theme
- bugfix in the configuration of the battery indicator and date on the lockscreen of the StattQualm theme
- smoother batterie-indicators and my private variant of the SQUAPE theme, called CMK.
- added some new Lockscreens
  • Like 4
 Share
Thank you for this award 😊
  • Thanks 2
Thunder Dick
emir71
Hallo erste mal,
aMir S
