FCSHARE 3.2.6
   (0 reviews)
These files are for dry vape devices only.
I recommend using the international version of Escribe.
Please load as file not as a theme open escribe then open settings from file .
These files are in the drop down download menu instead of in text area unlike most files.
Custom profiles  and tweaks to escribe settings have been made. A assortment of custom SS materials is also  preloaded.
Be sure to adjust with your mods resistance settings.
If unsure use of the mod resistance use  these settings (0.004)
The case thermal analyzer should be run for best performance on your DNA mods.
The below files include the case thermals for mod there based on. Other mods user should run this test.
DNA250 download is based off a Wismec Reuleaux DNA250 .
Profiles  for iheat, Splinter/ SplinterZ  and Stempod dry atomizers.
 Along with custom settings to puff time etc.
Included is a custom FC theme in the  DNA250  download
DNA250  Profiles contain the material cvs and setting.
iheatDNA.ecigprofile
SplinterDNA.ecigprofile
SplinterZDNA.ecigprofile
StempodDNA.ecigprofile
DNA250c based off a Lost Vape Paranormal DNA250c use with 2 battery mods
DNA75c based off elite
The maxs output temperature  is set to 465 in this file
Maxs puff time 20 seconds
If you need to go above the 465 degree  mod safety cutoff in the DNAc you will need to increase maxs output temperature setting.
These files have have profiles with custom setting for the Imp, iheat, stempod, splinter/ splinterZ.
Once  you install these files you can change the themes with out lossing these settings.
DNA250c Profiles contain the material cvs and setting. Load as a profile  please be sure to have room in active material files these upload a custom material and if material full  it won't install correct material. Delate nickel or one of others first.  If using an older SplinterZ with the newer 19/19 stems replace the material file with splinter  material  csv file.
Stempod.ecigprofile
SplinterDNAc.ecigprofile
iheatDNAc.ecigprofile
SplinterZDNAc.ecigprofile
IMPDNAc.ecigprofile
Material Files
Splinter.csv
iheat.csv
Cool.csv
Warm.csv
Hot.csv
DNA_FCTHEME.ecigtheme
test.ecigtheme
Elitetester.ecigprofile
Hcigar75c.ecig
EliteDNA75c.ecig
DNA75.ecig
What's New in Version 3.2.3   See changelog
Updated to DNAc file to the newest Frank theme.
