Clean Colors (75C/100C/250C w/Replay - Many colors available) v2.4
   (23 reviews)
What's New in Version v2.1   See changelog
Changelog v2.1:
  • Updated battery icons to more easily tell capacity
  • Updated Replay icons so they are colorless (works for any background color), and now it goes > NO REPLAY (not available) > SAVE (ready to save puff) > PLAYING (Replay active)
  • Screens rearranged to be more cohesive and consistent
Changelog v2.0:
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
  • Like 7
  • Thanks 4
Levtos
· Edited by Levtos
Looks great and simple.
Thanks
hawk256
Thank you!!
Frank65
Congrats !
RMoniz
Canucklehead
Glad you like it, thanks!
myk376
Deen
Logan
benjy337
Thanks very much.
Amon
Tortuga
CoxyofNewp
s3r
· Edited by s3r
weirdbeard
Ronbon172
niandra3
Mastervaper
  • Confused 1
maxbarrett
· Edited by maxbarrett
HarleyBill
feulipe
