Clean Colors (75C/100C/250C w/Replay - Many colors available) v2.4
   (23 reviews)
What's New in Version 1.3.1   See changelog
(Note: the screenshots show the battery icon is green, but that is only while charging. During normal use they are blue/white (see below). When battery charge is less than 20% they turn red.)
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
  • Like 7
  • Thanks 4
Levtos
· Edited by Levtos
Looks great and simple.
Thanks
hawk256
Thank you!!
Frank65
Congrats !
RMoniz
Canucklehead
Glad you like it, thanks!
myk376
Deen
Logan
benjy337
Thanks very much.
Amon
Tortuga
CoxyofNewp
s3r
· Edited by s3r
weirdbeard
Ronbon172
niandra3
Mastervaper
  • Confused 1
maxbarrett
· Edited by maxbarrett
HarleyBill
feulipe
