   (19 reviews)
  • Replay ready! (TC and wattage modes available too) - See below if you are having trouble with Replay
  • A LOT of other stuff.. check it out!
What's New in Version v2.0   See changelog
Changelog v2.0:
  • Also made a bunch of visual and usability improvelemts
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
Deen
Report ·
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
hawk256
Report ·
Thank you!!
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
niandra3
Report ·
   2 of 4 members found this review helpful 2 / 4 members
Share this review
Mastervaper
Report ·
Share this review
feulipe
Report ·
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Logan
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
