Clean Colors (75C/250C w/Replay! - Many colors available) v2.4
   (18 reviews)
  • Replay ready! (TC and wattage modes available too) - See below if you are having trouble with Replay
  • You can hide data on Main screen in Display settings (resistance, voltage, etc)
  • A LOT of other stuff.. check it out!
Here are the available color options. Let me know if you have requests for others.
What's New in Version 1.6   See changelog
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
Deen
Report ·
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
hawk256
Report ·
Thank you!!
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
niandra3
Report ·
   2 of 4 members found this review helpful 2 / 4 members
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Logan
Report ·
Share this review
Mastervaper
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
