Clean Colors (75C/250C w/Replay! - Many colors available) v2.4
   (18 reviews)
  • Replay ready! (TC and wattage modes available too) - See below if you are having trouble with Replay
  • You can hide data on Main screen in Display settings (resistance, voltage, etc)
  • A LOT of other stuff.. check it out!
Here are the available color options. Let me know if you have requests for others.
What's New in Version v2.2   See changelog
Changelog v2.2:
  • Fixed some items on the main screen what weren't positioned perfectly
  • Changed highlight/selection colors slightly for better readability
  • Added new ONE WATT version colors: now available in Blue, Green, Black, and Red
Changelog v2.1.2:
  • Added a ONE WATT version for those who want one-watt increments on the main screen. Wasn't sure if you all also wanted one degree increments on the temp, but that didn't seem useful so I kept that at 5. Note the it's currently only the blue theme that has the one watt version, but if you have requests for other colors, let me know.
Changelog v2.1.1:
  • Added Pride color scheme upon request
Changelog v2.1:
  • Updated battery icons to more easily tell capacity
  • Updated Replay icons so they are colorless (works for any background color), and now it goes > NO REPLAY (not available) > SAVE (ready to save puff) > PLAYING (Replay active)
  • Screens rearranged to be more cohesive and consistent
Changelog v2.0:
Changelog v1.9:
Changelog v1.8:
Changelog v1.7:
Changelog v1.6:
Changelog v1.5:
Changelog v1.4:
Changelog v1.3.1:
Changelog v1.3:
  • Minor tweaks and fixes
Levtos
Report ·
· Edited by Levtos
Looks great and simple.
Thanks
Share this review
Deen
Report ·
Share this review
Miamirican
Report ·
LOVE IT THANKS
Share this review
Amon
Report ·
Share this review
s3r
Report ·
· Edited by s3r
Share this review
hawk256
Report ·
Thank you!!
Share this review
weirdbeard
Report ·
Share this review
Levis1072
Report ·
Thanks for this theme
Share this review
Ronbon172
Report ·
Share this review
Frank65
Report ·
Congrats !
Share this review
RMoniz
Report ·
Share this review
niandra3
Report ·
   2 of 4 members found this review helpful 2 / 4 members
Share this review
Inferos
Report ·
Great and simple 😎
Share this review
Logan
Report ·
Share this review
Mastervaper
Report ·
Share this review
benjy337
Report ·
Thanks very much.
Share this review
Tortuga
Report ·
Share this review
CoxyofNewp
Report ·
Share this review
