This is a fully configured Escribe settings file for the new Lost Vape Mirage DNA 75C. Highlights:
  • All 8 profiles configured, with:
    • 3 temp control profiles for favorite atomizer and build combos. My go-to is the Pharaoh RTA as the primary profile, plus the Crown III and the SMOK Baby Beast for emergencies while traveling
    • 5 power-only profiles, at presets of 35, 40, 45, 50 watts
  • Includes my posted DNA 75C Enhanced Default Theme v2.2 which greatly expands the stock theme's capabilities
  • Standard materials plus two SS316L materials, one curve and one TCR set at 0.00094
  • Mod fully configured:
    • Battery Analyzer run for iJoy 21700 3750 mAh 40A battery
    • Cell Soft Cutoff set to 2.75V, max sustained discharge at 24A, max peak discharge at 35A for longer cell life
    • Output currents set at DNA 75C spec sheet typical rating
    • Mod internal resistance at 0.0031 ohms, measured with copper plug (actual 0.004 x 80%, minus an extra 0.1 mOhm for kick(s) :)
  • Built for EScribe Suite International v2.0 SP12 or higher, running beta firmware  v1.1 SP27 or higher
Hope everyone enjoys!
Recommended Comments
@mactavish
Congratulations on the new Mirage!
This posted EScribe settings file is already pre-configured to support 100W via the boost feature. You'll want to be sure to install EScribe International version v2.0 SP12 or higher, and apply beta firmware  v1.1 SP27 or higher to your new mod. You can then verify in EScribe under Mod, Safety, that the Max Output Power is set to 100W.
Correct concerning batteries; if you're using a single 18650, you can either download a battery profile for your specific battery, or use the EScribe 18650 default. To use the default, go to the Mod, Battery tab. Under Type, change it to Lithium Polymer temporarily, then back to Lithium Ion 18650. That will wipe out the iJoy 21700 profile with the default 18650, and you're all set.
Concerning battery safety, be sure to set the Max Peak and Sustained Input Currents to the ratings for your specific 18650 battery. Don't want to draw 24A sustained if the battery isn't rated for it!
Hope you enjoy!
Edited by Jasonvillamil
Share this comment
Thanks for the SUPER quick response! I hope you will add the REPLAY feature when that becomes available. Hopefully by then I’ll be up to speed on editing profiles by then, and I won’t need to bother you anymore. As a new Mirage owner, I was surprised not to see more themes for it, yours seems to come up in a search here, as one if not the only one so far that is Mirage centric. Also other generic DNA75C themes don’t include the detailed notes yours does, which says a lot to me about your work. Thanks again.
Share this comment
Absolutely! I have a new version of my DNA 75C Enhanced Default theme on standby ready to implement Replay; cannot wait for it to be released as it looks like a real game changer. Hopefully Evolv will have a beta up very soon.
Concerning the new mod, reminder that you can use any Theme that you want; there are some really great ones posted. This specific file is more about customized settings specific to the Mirage mod, and also happens to include my custom theme as that’s what I run on all of my 75C’s.
Share this comment
Thanks again for the support. I’ve been on board with TC from the beginning, have mostly moved on from Titanium to SS for my builds. I’ll be curious to play with REPLY after seeing the various reviews online with Brandon of Evolv. As long as I can still vape my rayon wicks dry and never get a dry hit, two of the biggest TC pluses for a flavor changer, it could be a very cool option!
Share this comment
