Please submit your reviews to support "Pro Vapers". I will send the Private Gold Version in the personal message box of the site to appreciate who have posted their review or followed this theme. Update: 2022-08-20
This is an enhanced theme for Evolv DNA color devices. Exposing the full capabilities  Priority and care were given to make this theme as clean, functional and intuitive as possible.  For designing This theme,  numbers of existing theme were studied and their strengths were noted. There are many many hidden fields and functions.
Minimum used space  (Off-Board memory and On-Board memory usage)
Easy Temp & Watt, Replay, Preheat and Boost mode Control.
And more features.
You can download the theme manual to get acquainted with all the features. Includes a guide to the features and additional information of the "Pro Vapers" theme.
Pro.Vapers_Manual_EN.pdf
Versions Info:
The features and menus of all versions are the same, but they are completely different in appearance
1- Portrait Version is designed to be quite simple for those who are tired of graphic designs and access to features and simplicity is important.
2- DS Version is completely graphic. It is the only template that uses a hand to display an analog ( analogue ) clock.
3- SG Version is a graphical template that tries to maintain the simple appearance of the portrait version, with the difference that a large slider is displayed around the screen fields and changes color with increasing or decreasing power or temperature.
4- Led Version is designed to look like electronic LEDs, and the fields are displayed with the appropriate font for these screens.
5- Army version with a simple appearance and silver and blue color for those who like military themes.
6- YL version   is iconic version with tall power numbers.
7- Gmatrix Version is a matrix green version with a different main screen.
8- Landscape Version is a horizontal display version for those who use horizontal themes.
9- Designers Edition is a version similar to the portrait version that is ready to use for design. You can easily change the colors or the background and create a custom version for yourself.
Theme Info:
Quote
Action Center:
Some custom themes have serious bugs in the   REPLAY / TC / BOOST implementation. The result is a frustrating disappointment with the promised possibilities of the DNA chipset and the user wonders what he has spent so much money on. "Action Center" screen help you to find and fix incorrect settings or settings not intended by Evolv in each profile. This allows you to rule out incorrect settings of the mod. "Action Center" screen tried to identify problems  and at any time it is possible to correct them without the need for a pc or spent more time.
In normal mode and when there is no error or incorrect setting, "Action Center" is not displayed, but when an error is detected, this feature is displayed as an icon on the home screen, lock screen and diagnostics  screen.
Locked Screen:
Main Screen:
System Menu:
Display setting Screen:
USB INFO Screen:
Lock Screen (lock settings):
PowerBank Screen:
Battery Info Screen:
Last Puff Screen:
Live Puff Screen:
Device Info Screen:
Custom Recording Screen:
New Atomizer Screen:
User Toggles Screen:
Diagnostics Screen:
By pressing the "Diagnostics" or Wrench icon in system menu you will be directed to the Diagnostics screen
Battery Optimization:
Used Abbreviations:
PWR: Power Mode
TCM: Temperature Control Mode
TC: Temperature Control
Pheat: Preheat
Curnt: Current
Temp: Temperature
ATTY: atomizer
Nrg: Energy
Puff T: Puff Temperature
Batt: Battery
Batts: Battery Pack
Flip Scr: Flip Screen
PWRBank: PowerBank
Cold T: Coil Cold Temperature
Peak: Peak Temperature
Ω Low: Ohm Too Low
Ω High: Ohm Too High
Overheat!: Too Hot
Fire from screens:
Customization Manual and Resources:
Quote
2. Download and unzip the Logos-1.zip, Logos-2.zip and Brands.Logos.zip.
3.
8. Save and Apply changes
9. Now it should show in EScribe, just upload it to the device  by "Upload Settings To Device" at the top of screen.
Logos-1.zipLogos-2.zipBrands.Logos.zip
Designers.Edition.Background.Series-1.zip
C- Modify and access to icon library
a25.gif.9d2953b48bbde38fa695df99ba027d2e.gifIn all versions you can modify screens and access to text icon libraryTo use icon library, you can choose/select the icon textually on any page or anywhere in the theme.
Special Thanks To:
 Description for Translate.txt
Hope everyone enjoys!
aMir Sirati
Edited by aMirS
What's New in Version 10.3   See changelog
- Update customization resources in theme description. (More than 200 logo Includes: Boxer, Centaurus, DeadRabbit, Dovpo, Drone, Evolv, Geekvape, HCigar, Hyperion, Lostvape, Mirage, Odin, Paranormal, Rebel, Steam Crave, Thelema, Therion,Thinkvape, Triade, VandyVape, Vapecige, VapersCloud, VaporGiant, Viciousant and ...)
Portrait.Brands.Logos-1.zip  Portrait.Logos-2.zip   Background.Series-1.zip   Portrait.Logos-1.zip
- Read customization and resources info in theme description for more info and help.
- Small changes in all version.
- And added more small features...
What's New Histor
Quote
- A new variant called the YL version has been added in download box.
- Some change in portrait version.
- Fixed LED version reported bug.
- Adding a new feature called Action Center in all variants.
- Reduced used space.
- Fixed Army.D version TC mode.
- A new variant called the ARMY.D  version has been added in download box.
- Fixed SG  variant in 75c mods. now it's available again in all DNA Color mods.
- Modified portrait version background.
- Added some smart notifications and warnings (all versions).
- Added back button in all fireable screens (all versions).
- Added lock shortcut in LED version main screen.
- Added firing view in LED version main screen.
- Updated icon and logo library(all versions).
- Added customization info &  resources   in theme description. (Includes: 30 custom background, 69 custom logos, 200 icons and mod logos)
- New Silver  Beta Version
- Modifying Action Center in all variants: Some custom themes have serious bugs in the   REPLAY / TC / BOOST implementation. The result is a frustrating disappointment with the promised possibilities of the DNA chipset and the user wonders what he has spent so much money on. "Action Center" screen help you to find and fix incorrect settings or settings not intended by Evolv in each profile. This allows you to rule out incorrect settings of the mod. "Action Center" screen tried to identify problems  and at any time it is possible to correct them without the need for a pc or spent more time.
- In normal mode and when there is no error or incorrect setting, "Action Center" is not displayed, but when an error is detected, this feature is displayed as an icon on the home screen, lock screen and diagnostics  screen.
  • Like 3
  • Thanks 4
ZumaFx
Atlantis
Thanks!
Kenz0r
Thanks for the amazing work!
Sflow
Papaws Vape
THANKS AND WELCOME BACK
WLM88
· Edited by WLM88
KRYSS
All the best.🌹
Beefstu2000
mjkroth
I love this theme! i use it on my Geekvape Z 100c. i'm using the DS version and i love the organization of this theme, it makes it very easy to use. you don't have to be a pro to use this theme. the way it is set up every option is right in front of you. its great!
You’ve left a smile on my face with your kind words. Thank you so much for sharing this review. 😍
Kent8mg
This is the best DNA75C.100C.250C theme I've ever come across, it's really beautiful and made with great care.Thanks for sharing and good luck
这是我遇见过最好的DNA75C.100C.250C的主题,真的是很漂亮,而且很用心去制作。谢谢分享,祝你好运。
You don’t know how much your fantastic feedback means to me.i sincerely appreciate you taking the time to share your experience  😍
CJOBE
I run this theme on all my dna devices. I currently have (2) 250Cs and (1) 100C and use this theme exclusively due to the ease of use, customization and looks awesome.
I appreciate your kind words about the Pro Vapers theme. Really makes me happy to hear you like it so much!  Thank you again for taking the time to post a review.  🙏
Conor
So much to love here. I signed up just to say one of the simplest features is one of my favourites. A 24h clock! Fantastic work.
Just wanted to let you know I'm thrilled to hear you enjoyed it. Thank you for your   registration and kindness. Its very valuable to me.😍
Phammer1
· Edited by Phammer1
Been using the led theme and it's perfect! Every little detail is spot on, best themes by far! Most functions out of any other themes and love the action centre. Can't ask for more
There’s nothing better than receiving a glowing review. im thrilled to have you as part of the pro vapers family! Thank you for sharing your kind words. ❤️❤️❤️❤️
Butcheck
For me this Theme is the Best that I am using so far, has the most functions, easy to use. 11/10 for me. Thanks so much @aMirSfor making this wonderful theme! Really appreciate the work mate!!! ❤️
I sincerely thank you for the kind words you said about pro vapers theme.I hope you enjoy and have fun with Pro Vapers. 🌹🌹🌹
Sarnog
I used a different theme for a long time (triade theme), but this one is better looking in my opinion and has way more options! From now on, i'll stick with this one and hopefully the gold edidion because i think it looks even greater then the normal DS version.
I am very happy that you chose the pro vapers theme and thank you very much for your positive feedback 😊. I have sent you the gold version, I hope you enjoy it ❤️🌹
chardyboy
Wow! just Wow. Very nice theme and important details are displayed very well. Thank you bro.
I sincerely appreciate you taking the time to register and share your review. This is very valuable.😍
florinji
I started using this theme and I am very happy with it.
Thank you for your positive review, I am also very happy too. Hope you enjoy it. 😍
Tdawg42872
Definitely love this theme, works great,easy to understand
I will love to read the kind words you left about pro vapers theme! Thank you for the review 🌹
HandlebarJase
What a great theme.
aMirS was super quick and responsive helping me out with an issue customising my Rebel Mod.
Lovely theme that fits my mod perfectly. Even better now that it has the REBEL logo as well.
Great theme, great themer Keep up the great work. 👏👏👏
Thank you again for taking the time to share your feedback it’s always appreciated.😍
Note: in customization info you can download backgroundsDesigners.Edition.Background.Series-1.zip and find custom wally designed for reblel vape 🌹
Zoltan
Very nice theme and easy to manage. If anyone looking for a good theme for the mod. Then you don't have to look any further because this is the best.
It is not every day that i receive comments as detailed and thoughtful as yours. I sincerely thank you for taking the time to share your review. ❤️❤️
JD210991
Francixko
Dernier Théme Gold (gentiment partagé aprés un petit mail au créateur) installé sur ma Steam Crave HADRON PRO
Théme stylé,trés comlplet et super Fluch avec mon Ragnard Gold !
Du super boulot , on en redemande 😉
Merci ! Vos paroles m'ont remonté le moral aujourd'hui. C'est agréable d'entendre vos gentils mots.
drminol
· Edited by drminol
Awesome theme! Best of the best! Looks and works great!
it gives me much pleasure to know that you’ve chosen to stay with pro vapers. Your kind words encourage me to continue doing my best, have a wonderful day.
Sir Coils
· Edited by Sir Coils
Suthiwas
· Edited by Suthiwas
