Landscape DOVPO® / ODIN-SPECIAL - Five Designs
   (0 reviews)
What's New in Version V4   See changelog
RECOMMENDED UPDATE
- Redesign of the puff info screen (chart display) with an expanded selection of the graphs to be displayed
- Autolock control
- Added stealth mode (with explanation)
- Stayalife enabled (with warning)
- Changed display logic in replay mode; now the output of the last puff is displayed even after standby
- Slightly changed display of the menu bar on the main screen
- Memory saved where possible without visual impairment
