NEO Cloudz [on Crack™] {DNA250C + DNA75C} NP20
   (3 reviews)
This is the most advanced, feature packed vaping experience OR YOUR MONEY BACK!!!
Pick up your vape.
Have a taste of 2077, have some NEO Cloudz.
HATE THIS???
Please fill in the following (very short) feedback form :) I would really appreciate it, especially if you DON'T want to download this. I want to make this better for everyone!
https://forms.gle/bSKWzHjmYJoyAmrE6
Do you think I have desecrated the holy sanctity of Frank?
This theme didn't used to be this hot 🥵. Think of this version as a spiritual successor to Frank's before, erghmm, it got hooked on all that... pink. Also check this for a more comprehensive change log :)
Neo Clouds On Crack has Frank at it's very core, hardened and sharpened until it's latest iteration. This.
Dev Style:
I'm a massive h*cking nerd if you couldn't already tell. This theme is themed after a computer terminal as that is where I spent most of my days. I love the minimalist high contrast look and wanted to bring that l33t l00k to not only to just my vape but YOUR vape!
A new version is submitted as I create them. While this means you will get extremely fast updates; this also means you *will* experience bugs and inconsistencies in the UI. Report them if you care. I am only human however meticulous I am.
Edited by Skit
What's New in Version NP20   See changelog
  • increased default timeout to 20s
  • reduced the size of the profile selector to better emphasise the accent box
  • changed lockscreen password caption to be less esoteric
 Share
Recommended Comments
On my review page you responded and wrote “
I've misread your reponse. It's in the lock settings, look for the key icon on the settings page.”
The device lock setting is there, I’m talking about the SCREEN timeout. Using Escribe, I edited the Theme directly, under “ACTIVE” time, set mine for 20 seconds.
Ah, I'm sorry. I don't think this is possible with the current EScribe software. Take it up with Evolv. I cannot do anything about this. Unless Evolv makes EScribe open sourced any time soon I doubt it's in my power to do so.
Sorry, I'd love to do that as well.
It’s not a big deal, it’s a setting you have chosen in the Theme, just like an image. I just have to remember to change the screen time out every time I update to a newer version. I see you have already done some minor updates, so I’ll wait awhile. As you know there are still a lot of settings that can’t be changed directly on the device, like the LED colors, fade times etc. Unfortunately, the screen timeout is one of these settings that can only be changed in the Theme Editor, which I know my way around a bit. Keep up the GREAT work !
Edited by mactavish
New update coming in 5 minutes. I got a hot new pink theme. Let me know what you think. I make this theme as I use it personally so if people don't like the pink I'm might have to maintain a "clean" version.
Yeah, I like the theme the way you had it. Of course you make it for your own pleasure. I know there is a way you can have multiple versions available, just come up with a good naming convention. You could just add “pink” to the version number perhaps.
So yes, please keep a CLEAN version.
Edited by mactavish
New update is out. The last "clean" version is 39. There is no changes to the functions yet only a visual overhaul with some basic filters to make it pink. This will be fully redrawn by me personally eventually. This theme is going to look much better in a few weeks.
Это очень мощная разработка, но тема не сильно изменилась после Frank65, основная ошибка этой разработки осталась, это возможность включать Replay без отключения Temp control. Переигровка это режим контроля мощности и отображение температуры некорректно. Вы немного не понимаете суть режима Replay и даёте пользователям ложные надежды по настройкам температуры в этом режиме. В целом все очень хорошо, но недочеты созданные Френком остались и у Вас, хотя найти их при работе мода очень трудно и это мало влияет на качество проделанной Вами работы. Желаю успеха!
p.s.
Режим Replay возможно активировать для любого профиля с TC material попробуйте реализовать эту возможность. Так же кнопку Reset statistics лучше убрать на отдельный экран, для устранения случайного нажатия
p.s.
Thank you very much for this report. Can you speak english? If not; that's okay leave it in your native language I'll be using google translate so keep that in mind please :)
Can I ask you 3 things my friend and it's very important that you describe to me ***exactly*** what it is in as much as detail as you can.
*What do you think replay should do?
*What do you think replay in my theme is doing?
Have you seen it work the way you want it to in another theme?
It's very important to me to know the 2 first questions. If I don't know what you want I cannot make you happy :)
I'll see about the the reset. I have never found it to be a problem but I'll see if I can add it. I don't want to say confirm this as a feature as there is a screen limit. I have 8 more screens that I can add to this theme. While I don't think I will hit this limit and will be implementing this soon please do keep this in mind if in a future update it is removed.
1. Replay поддерживает параметры сопротивления катушки которые были при эталонной затяжке, при этом не используются алгоритмы расчета температуры катушки, нагрев идет до достижения сохраненного значения сопротивления, далее мощность снижается для поддержания параметров как при Сохранить затяжку. Повторяю расчета температуры нет, по этому не важно знать TCR материаля, важно чтобы материал менял сопротивление при нагреве.
2. В Вашей теме Replay всё делает правильно, но отображение температуры при Replay это ошибка, которая вызвана несовершенством програмного кода Escribe.
3. Посмотрите мою тему, там есть и версия на английском, англиская версия менее усовершенствована по сравнению с русской, но этот вопрос там решен.
4. Я не буду использовать твою тему и мне не важно как работает твоя разработка, я искренне хочу помочь сделать качественный и удобный продукт для всех пользователей.
Будь уверенным в себе, изучай опыт других и станешь лучшим. Удачи
4 minutes ago, zark said:
1. Replay поддерживает параметры сопротивления катушки которые были при эталонной затяжке, при этом не используются алгоритмы расчета температуры катушки, нагрев идет до достижения сохраненного значения сопротивления, далее мощность снижается для поддержания параметров как при Сохранить затяжку. Повторяю расчета температуры нет, по этому не важно знать TCR материала, важно чтобы материал менял сопротивление при нагреве.
39 minutes ago, zark said:
Okay, but it doesn't. Once the user presses the fire button the temp no longer exists and changes to just the wattage. This is due to a flaw in how the screens update. There is nothing wrong with this.
  • Haha 1
- Исправлен повтор , теперь у него есть мощность, а также темп. Используйте повтор как хотите!
Это ты написал в описании. Ещё раз повторяю, тема очень хорошая, но описание слишко самоуверенное, поверь в этой теме есть над чем поработать.
Удачи!
Забыл сказать, мой DNA мод сломан и у меня нет возможности тестировать твою тему, мои выводы сделаны из анализа в Theme designer. Я сам провел множество часов переделывая тему Френка, по этому я четко вижу изменения внесенные тобой в исходную версию, если честно я вижу много измененений в дизайне (хороших измененений) и не так много измененений в самой структуре темы, использование других условий для настроек параметров тоже незначительно.
Я ни в коем случае не пытаюсь уменьшить значение твоей работы, но пока это немного изменённая тема Френка (это относится и к моим темам)
Я ожидаю, что кто то наконец создаст полностью совершенную тему, и стараюсь помочь в этом. Моя критика это моя помощь тебе.
That's fine my friend. A MASSIVE update is coming in a few hours. The UI is completely reworked with new assets as well.
24 minutes ago, mactavish said:
I’ll be sticking with your last BLACK version. Good luck going forward. Thanks for that update.
May I ask what do you dislike about the new version? Or more importantly why you have chosen to stay on the black version.
I prefer BLACK over PINK...
It's mostly purple lol, I just say pink as it's more provocative. Try it on your vape, you can always undo it. The new UI has lots of new features compared to the version B0. Granted I just finished it around a few hours ago so it's no where near as polished as version B0 but it'll be in a few days.
Looking at the new screen shots, don’t like the Temp and Wattage moved to bottom of screen. Hey, it’s your design now, make it however you like. I’ll stick with the “B0” version, and either update that one if I see something added that is necessary, don’t see any major improvements that I need in the latest “P” versions. Or I’ll find another theme. You did a great job on updating Franks version, and I appreciate that, but your work has taken you to your own theme now, good luck!
Thank you my friend :) Stop by every now and then, I'll miss you 😢
Дружище, мне кажется, что ты сильно увлекся стилизацией DOS. Теряется привлекательность и читаемость темы. Поле Status на главном экране должно быть большим, чтобы читались сообщения об ошибках. Также нужно поработать над текстом на вкладке Язык, иначе не очень понятно что пишет плата в поле Статус. И вообще нужно стремиться к тому, чтобы все надписи и сокращения в твоей теме были понятны любому пользователю (все мы используем один и тот же сленг, термины и аббревиатуры, не нужно выдумывать ничего, это оттолкнет начинающих пользователей, которые не изучили тематическое оформление)
NP7 я не вижу, как выйти из вкладки Главный экран, я не нахожу ни одной команды Go to, условия выхода за границы экрана тоже отсутствуют. Пропущена буква в Pwer => Battery
Это мое имхо.
Удачи! Твой путь не прост, но интересен!
Edited by zark
Это мое имхо.
Thank you my friend. I've noticed this as well. I have made several trades offs in my own theme in an attempt to make the UI look slicker. While it works great for me it doesn't work so well for new users.
It's the top right corner for the rest of the settings. I think I'll be making a new graphic to explain the UI.
You are correct in saying I may have gone too far. The style I've chosen has given up far too much for novice users. I plan to address all of these today and make the UI easier for a new user to use. The trades offs in this new "cool" look simply doesn't fit the use case of the vape UI and will need major step backs.
April 13, 2021. The download count has been spammed for this theme by an unknown user(s) due to this same action (spamming) from other theme designers. Wanna be losers looking for imaginary internet fame. This same comment is posted for the current 5 themes shown and the prior 2 Top themes.
Probably someone trying to cover their tracks by spamming. I'm not doing this.
