   (39 reviews)
What's New in Version 2.8.5   See changelog
rev2.8.5 REPLAY- May 18 2018
settings.png.c89f1ab16caf163cd2acabe83e42eb1b.png      piumeno.jpg.f1d01095d4f3183d8661ca6aee2faf95.jpg    ==>   moresettings.png.cae2d2a258ce2e6d3499d5f4d017db07.png
Minor bugs fixing
Thanks for your attention  :)
mjordan79
Report ·
· Edited by mjordan79
Share this review
Frank65
Report ·
Share this review
GrumpyJoe
Report ·
Share this review
FrankieS
Report ·
Share this review
noxtradamus
Report ·
  • Thanks 2
Share this review
eckotek
Report ·
· Edited by eckotek
Then push reset :
Share this review
clivy
Report ·
Share this review
Chodi
Report ·
Share this review
Hearts
Report ·
Share this review
yanoostar
Report ·
Grazie Frank65
Share this review
N8dizzle
Report ·
Share this review
bigbells
Report ·
Share this review
konn4312
Report ·
Share this review
Canadianvape
Report ·
· Edited by Canadianvape
Share this review
Aavatar
Report ·
Keep up the good work mate!!!
Share this review
ronnyko
Report ·
sorry about that.
  • Confused 1
Share this review
myk376
Report ·
· Edited by myk376
Share this review
mactavish
Report ·
Share this review
chinoloc1
Report ·
Share this review
vapondragon1
Report ·
Primo Ti 21700.ecigtheme
Share this review
saiak
Report ·
Share this review
nightwire
Report ·
Share this review
JapoBR
Report ·
Share this review
rubassdj
Report ·
· Edited by rubassdj
Share this review
Ping
Report ·
Share this review
