The following screenshots are from my basic themes for dna75c / 250c - just for vaping V3.1; are however fully implemented in a customized design:
PLEASE NOTE:
TO THE EXPERIENCED USERS:
What's New in Version 4.3.2   See changelog
Technical and visual adjustments to the current enhanced version
Recommended Comments
If there are problems with the font used in the LCARS-theme, it may be due to the fact that you certainly do not have it on your pc. Therefore the download link can be found here:
https://gtjlcars.de/LCARSindex/LCARSFONTS.htm
Direct download LCARS GT3J.ttf
If there are problems installing the font on Windows 10 -
adding-new-fonts-to-theme-designer (Thanks to user Formula 1)
Edited by gwyar
Share this comment
For everyone who is interested in this theme: I am currently working on an enhanced version that exceeds all (my) previous themes.  The interface will be switchable between English and German, 4 different lockscreens to choose from within the same theme and almost everything that the chipset makes possible.  At the moment I am in the final test phase, the release is planned for May 1st.
Für alle, welche an diesem Theme interessiert sind: ich arbeite gerade an einer enhanced Version, welche alle (meine) bisherigen Themes übertriffft. Die Oberfläche wird zwischen Englisch und deutsch umschaltbar sein, 4 verschiedene Lockscreens zur Auswahl innerhalb des gleichen Themes und fast alles, was der Chipsatz möglich macht. Im Augenblick befinde ich mich in der finalen Testphase, die Veröffentlichung ist zum 1. Mai geplant.
Share this comment
