All Activity
This stream auto-updates
  1. Past hour
  2. Just an aesthetic upgrade for fellow vape Jedis Rebel DNA 75C INT off Default.ecigtheme
  3. Unfortunately, I have to report that Evolv are talking absolute rubbish, it was an easy repair that took about 20 minutes. RS online sell the zif connectors for less than £5 for 10 and they are easy to install.
  4. Today
  5. first try of making a theme. ive put a puff counter on the main screen and changed the date settings to English format dd/mm/yy Tigers.ecigtheme
  6. packgirl04
    Paranormal DNA 250C
    Ok. Thank you for your help
  7. Wayneo
    Paranormal DNA 250C
    Sometimes N80 coils will work but it's not as consistent as using proper TC material. There is a setting, but you're better off in the long run using the proper material/wire.
  8. packgirl04
    Paranormal DNA 250C
    I’m sorry I should have clarified. 2 NI 80 coils. I did some research and found that replay won’t work with NI 80 coils. What confuses me is why was replaying working at all
  9. Wayneo
    Paranormal DNA 250C
    When you say 2 Ni coils, are you talking Ni200 (pretty much pure Nickel) or like N80 or N90 (Nichrome)?
  10. Chanson
    Full build kits
    I was wondering where I can purchase a complete do it yourself build a mod like the cnc b box and so on if I am saying it wrong please let me know
  11. Yesterday
  12. Hi everyone. Hoping someone could help me out. I have a Paranormal DNA 250c and I was running it in replay mode using 2 Ni coils with no problems. Last night I took the tank off to clean and rewick. When I put the tank back on, I can’t get replay to come on. I didn’t change any coils. Just cleaned them and rewicked. It was working fine before I rewicked. Don’t really know too much about escribe. But I’m thinking there maybe a setting in there I don’t know about. Any help would be appreciated. Thank you
  13. Спасибо огромное за Вашу тему!
    Тема супер! Большое спасибо.
  14. retird
    Dna 250C ohms readings wonky.
    Read thru this thread and wonder if you have tried this basic exercise....... Have you made a single wire spaced coil (not alien) and tried that. Use wire Material such as Kanthal, SS316L, etc. Check the ohms reading with an ohm's reader before using (reading would be the cold ohms). Device is at room temp and atty at room temp before firing as a new coil? Fire device and select "New Coil" What reading do you get for Cold Ohms? What reading do you get for Live Ohms?
  15. David B.
    AS you can read earlier in the thread, ive used 3-4 different attys on it and they all are showing the same problem. so its not that. The voltrove v3 35mm im using right now is brand new anyway. but thanks for caring enough to recommend something.
  16. Last week
  17. TorturedZen
    Qwik Question Re:Replay mode
    Це добре для вапрів, ніж! Добре.
  18. VapingBad
    Don't forget the atty, so many have a centre pin that screws in which after lots of heat-cool cycles loosens and lets in dirt, try loosening a tiny bit then tightening all threads in your atty that are part of the current path.
  19. David B.
    Fuck man, i think you might be right, i tried to press the centre pin in using a tiny bit of pressure, with a screwdriver and even just nudging it with the driver the 510 makes a slight clicking sound. before it has even movced down 1-2mm. i never thought that might be it, but it kinda makes sense if it was.,
  20. awsum140
    Don't forget to check the 510 itself. A weak spring or bad center pin,not enough travel or too short, can give you real headaches like this.
  21. zark
    В общем - никак, законодательно нет четкого разделения между вейпингом и курением аналоговых сигарет, но при этом и замечаний от полицейских по поводу вейпинга в общественных местах я не слышал
  22. TorturedZen
    Як діють закони про вапінг в Україні?
  23. David B.
    I have personally re soldered all the connection points, the only thing i havent done yet so far is re tighten the 510 and the ground lug, as im waiting for the tool in the mail from the uk. Thanks for all your help. i just wanted to make sure it was the only thig left it could be and not an issue i could have fixed in the evolve software, as it gives the right live ohm readings. ill wait until i get the tool and try to re tighten it and see if that fixes it.
  24. zark
    Я возможно не все правильно понял из перевода но live ohms= 0,223 Ом, при этом cold ohms= 0,315 Ом, мне кажется, что это либо бред, либо Вы используете разогретую катушку при замере cold ohms (я не думаю, что Вы меняете показания cold ohms вручную, возможно Вы прогреваете атомизатор при замене или при фиксации данных), возможно Вы используете некорректный TCR, либо у Вас очень принудительно сильно занижена комнатная температура. Я более склонен к тому, что у Вас есть проблема с плохой проводкой либо плохой контакт.
  25. retird
    DNA GO 30-40 watt Born Just for Pod?
    Oh, you can post in your language as we can translate easily here.... might be easier for you and for us....
  26. retird
    We don't need date of purchase here. Best case with Evolv is that they may want you to send them the device or maybe just the board out of the device or maybe they just will send you a board.. They will guide you...
  27. Pino74
    tomorrow I put screenshots of the date of purchase of my box with references.Now it's 4 in the night in Italy. I'm going to sleep.
  28. Pino74
    I bought the mod precisely 15 days ago, but I realized a few days ago the problem, I wait for the evolv answer first, for me regardless of everything, even if evolv recognizes a problem and wants to replace the circuit or repair it, it is always a problem, wait, shipping etc.I live in Italy, tomorrow I hear the online shop that sold it to me, but I'm sure they will be smart, and they will ask me how can you say that it doesn't work well? they will complicate my life not to take an assignment on a product where they have already earned, for them the returns of material are problems,they don't want to have. moreover I will be without mod until then they send me a repaired or new one and the vendor I am sure that I will not change the mod, but will send it to the wholesaler, and then I have to wait for who knows how long, maybe it will be sent to China.the vape shops are not like amazon, after selling something they try to avoid all possible problems, returns, guarantees, replacements, repairs etc I keep you updated. Anyway thank you
  1. Load more activity
